dudemax37 |
06-12-2019 07:50 PM |
2003 dakota 3.9 cat y pipe options
Hello I recently purchased a 2003 Dodge Dakota with the 3.9L w/ reg cab & 112" wheel base, 2wd/RWD, SLT. It needs entire exhaust from manifolds back. I prefer a direct fit. The only part of the exhaust left is the 2 cats bolted to the manifolds. The rest is cut off behind it.In my search for the right setup I saw some Doorman 2 cat y pipes (with no 3rd) listed as 3.9L /5.9L for dodge dakota's but have no idea as to fitment I also saw some listed that said 3.9 4.7 5.9 from same company. Im also wondering if you can use the 4wd pipe with the RWD? Is there a difference? is it just a parts listing thing? same with the 5.9 question? But can only find these references from ebay sellers. If anyone has any knowledge on if those parts are cross compatible? I didnt want to just jump into a magnaflow cat setup as cost is a factor. Id like to not go with a 3 cat system unless i have to since its already set up with the 2 cats and has no CEL's.
I appreciate any help, advice and recommendations available. Thank you in advance.
