2004 Dodge Dakota Starter or Fuel Pump
Old Sep 1, 2019 | 06:17 PM
turboroybal's Avatar
turboroybal
Default 2004 Dodge Dakota Starter or Fuel Pump
I have a 2004 Dodge Dakota Quad Cab V6. I just had the starter replaced no more than a month ago and I tried to start it yesterday and I got kind of a whining sound when I turned the key. Sort of the sound you might hear if the starter was going out. I tried it two more times and the 3rd time it did turn over. I had a "reputable" mechanic replace the starter but before I start pointing fingers, could the fuel pump be going out? About 4 weeks before the starter went out I noticed it was taking a bit longer for the engine to turn over. In other words, when I turned the key before the engine wouldn't hesitate to turn over, then all of the sudden it was taking a good couple of seconds to turn over. So now since the starter has been replaced and I am still having trouble starting the truck, could it now be the fuel pump? Thanks in advance for any positive input anyone has.
Old Sep 1, 2019 | 09:45 PM
magnethead's Avatar
magnethead
fuel pump won't affect how fast the engine spins over. Corroded battery connections will.
The fuel pump affects how long the engine spins over before catching.
