Bolt compatibility question
Old Nov 18, 2019 | 12:32 PM
Brian Fuller's Avatar
Brian Fuller
Default 99 Dakota upper control arm Bolt compatibility question
I am replacing the bolts on my upper control arm and having difficulty finding the part number 06505393AA bolts that the manual states it needs. These are M14X2.00X45.00 bolts. My question is will any M14X2.00X45.00 bolts work? If not does anyone have a link to the correct bolts that are available for purchase?
Here are some samples of some M14X2.00X45.00 Bolts.
https://parts.chryslerjeepdodgecityo...cation=9008200
https://www.morris4x4center.com/mopa...07152aa-m.html
https://www.morris4x4center.com/bolt...6507152aa.html
I have a 99 Dakota 5.2L V8 SLT Club Cab with the 44RE Transmission.
Thanks,
Brian
Old Nov 18, 2019 | 07:11 PM
magnethead's Avatar
magnethead
Yes any standard bolt will work. A flange-headed bolt is ideal, but not required if you put a washer under the head of a standard bolt.
