1999 Dakota 3.9L v6, P0118 code
Old Jan 29, 2020 | 03:42 PM
Doc Hojo's Avatar
Doc Hojo
Default 1999 Dakota 3.9L v6, P0118 code
Hello, thanks for opening my thread!
I bought my first Dodge last Thursday, a 1999 Dakota 3.9L v6 with 166k miles. Truck is running fine, waiting until my next few paychecks to do the plugs, wires, belt, brakes, etc just to tune up the truck and eliminate any simple problems that be in the near future.
I'm getting one error code : P0118, engine coolant temperature sensor. I've replaced the sensor, still have the code. I used a volt meter to test the connector, it reads 5.15v while set on "9V BATT". I'm presuming the fuse and the wire are okay or else the electricity wouldn't be making it to the connector. What else could be causing the code to continue to come up?
Also, how dangerous is it to run the truck with it not sensing how hot the coolant is?
Old Jan 30, 2020 | 12:12 AM
magnethead's Avatar
magnethead
measure the voltage across the 2 wires going to the sensor, with the sensor plugged in.
If you are getting 5.15 across the 2 sensor wires with sensor unplugged and key on, then we think it's getting power and ground.
Old Feb 2, 2020 | 07:56 PM
wheily's Avatar
wheily
i know on our 96 jeep grand cheroke there is a second temp switch in side of engine block by motor mount on driver side ..not sure if dakotas hav it to we ignored that code in jeep for 8 years
