band adjustments
Old Mar 10, 2025 | 04:52 PM
TheB00g's Avatar
TheB00g
Default When you say free play.
Originally Posted by master tech
Take it from me. Don't use the band adjustment specs. What want to do is loosing the retaining nut on the front band which is you kick down band, adjust the band until you have 1/4 to 1/2 of free play. Do the same on the reverse band too. And make sure you tighten the retaining nuts.
When you say free play,
You are referring to the adjustment screw before it touches bottom?
