parking lamp wire rubbing???
Old Dec 19, 2005 | 09:42 PM
97dak39's Avatar
97dak39
Default parking lamp wire rubbing???
ok i have a 1997 dakota with a 3.9 5speed. when i pull my light switch on the first notch for just the parking lamps, the fuse blows right away. u can put a new fuse in it and pull it right back and blows again. what is my problem? is a wired chaffed and rubbing on something? thanks
Old Dec 24, 2005 | 02:43 AM
titan2087's Avatar
titan2087
Default RE: parking lamp wire rubbing???
Hmmmm it sounds like its grounding out to something probbely a good chance the wires rubbed threw some where like you said i recon your best bet would be to follow the wire espically in the tigher ares and make sure it hasnet chaffed against the engine or frame. Good luck
Old Dec 24, 2005 | 09:55 AM
97dak39's Avatar
97dak39
well i think im just gonna take it to a shop and let them rip apart the truck
