Manifolds
I have a 2000 Dakota w/4.7 and I just changed the manifold to a 08 and was wondering what to do with the sensors? The TB and the MAP are easy but where do I put the the one right below the idle? I don't know the name of it? It fired up it was running rough and now it won't start. I'm going to pull the top end off this weekend to change my heads, HO cams and new timing while my other HO cams are being sent to Crane for a regrind not unless anyone has a set of 206's? I don't want anything bigger because I don't need the higher duration.
Thanks for the help
Thanks for the help
