2001 Dodge Dakota Airbag Control Module Replacement
Old Oct 4, 2020 | 07:19 PM
N1CK's Avatar
N1CK
Default 2001 Dodge Dakota Airbag Control Module Replacement
My 2001 Dodge Dakota Quad Cab 4.7L has had the airbag light on for as long as I've owned the truck. Finally got a code reader that can read and clear SRS codes. The fault it read was "ORC Output Circuit Diagnostic Code". Clearing the code does nothing which has led me to believe the airbag control module itself is bad. I am confident in my ability to replace the module safely. My only question is this, do these modules require the correct VIN to be flashed to them? Finding a new module is proving to be impossible so I am looking at rolling the dice with a junk yard unit.
UPDATE: Found another Quad Cab 2001 Dakota in a salvage yard that still had its airbag control module and wasn't in a wreck. Made sure both part numbers were identical and made the swap. No more airbag light! Just wanted to update the thread with how I resolved the issue in case someone else could use this information in the future.
