How to tell if I have 4-wheel ABS.
Old Dec 25, 2005 | 02:26 PM
95sport's Avatar
95sport
Default How to tell if I have 4-wheel ABS.
I'm trying to figure out if my 01 Dakota has 4 wheel ABS. What will I find under the hood to tell me what I've got.
Thanks, Travis
Old Dec 26, 2005 | 01:08 PM
Muy_Pyro's Avatar
Muy_Pyro
Default RE: How to tell if I have 4-wheel ABS.
.... You'd probably have an "ABS" Light on your dash somewhere ... I would assume.
I don't think there would be anything under the hood? ... You could always go to a parking lot and try locking your brakes up on some snow! If you slide, no anit-lock brakes; If you hear a chatter like your brakes are hooked up to a M-16 Machine Gun, You have 'em!
[sm=icon_cheers.gif]
Old Dec 27, 2005 | 05:40 AM
dodgeman4x4's Avatar
dodgeman4x4
in my dak there is a sticker inside the glove box that tells me all about my truck. Such as my 4wheel abs, 3.9 rear axle with limited slip and the larger 10in brakes in the rear...jealous.
Old Feb 22, 2006 | 03:42 AM
HUEY420's Avatar
HUEY420
look under the truck on the inside of the wheel if there is a wire harness near the brake line that would be for the abs on the rear abs there should be a sensor located on top of the diff if there is a harness at both front wheels and one in the rear u have 4 wabs
