Temp Control Vent control Backwards!
Old Apr 15, 2021 | 12:26 AM
Shawn Brown's Avatar
Shawn Brown
Default Temp Control Vent control Backwards!
I have 04 dodge Dakota , and my temp control and vent control ***** are backwards, if I turn on defrost it's turn heat on up turn temp control **** to change the vents.. any help be much appreciated.
Old Apr 15, 2021 | 07:05 AM
Has it always done this or just started? Checked the vacuum lines?
Old Apr 15, 2021 | 08:39 AM
Dodgevity's Avatar
Dodgevity
04 Dak won't have vacuum lines for climate control.
OP, was any work recently done on the system? Pull your battery cable, short out the terminals and turn the key to start pos for a full reset.
Old Apr 15, 2021 | 07:18 PM
Shawn Brown
I did some looking and noticed where ssomeone has changed the heat resister plug would this have anything to do with it? Wires are badly spliced together.
