Crank no spark
Old Jun 30, 2021 | 06:11 PM
Frank Guerra's Avatar
Frank Guerra
Default Crank no spark
First I know this is my fault, I was bypassing the fuel pump with the wire an I hit metal an a spark .well after that it didn't want to start no more..now everything I am putting down is new.wires plug dis Distributor cap roteR Pick up coil.I have a 03 with a 5.9l. No codes are showing ...I am going crazy trying to figure this out
Old Jun 30, 2021 | 06:40 PM
magnethead's Avatar
magnethead
Check ALL fuses, both in PDC and in the cab. Can you hear the fuel pump prime when you turn the key on?
I don't think the ASD relay itself has a fuse, but the fuel pump and fuel injectors do.
Old Jul 5, 2021 | 12:17 AM
Frank Guerra
Yes I check all fuses an I do hear the pump..its getting plenty of fuel. I check the add relay its good. An yes it does have a fuse it is a 30 amp.I have everything new all the way down to the pickup coil.the only thing left is the pcm..I am going to check the ground input for the pro..I don't think I'm getting the 12v to the coil
