OBD communication problem and no bus message
Old Oct 27, 2021 | 06:22 PM
Ally2332's Avatar
Ally2332
Default OBD communication problem and no bus message
I have a 99 dodge dakota. I recently hooked the OBD back up. A few years ago the plastic casing broke. All the wires were there and connectors looked good. After installing the new casing I tried using it and it powered the code scanner on but said no communication and was unable to read the codes. I tried a different scanner and same thing. The second time I tried tho the odometer flashed “no bus” all the lights shut of then immediately came back on and the no bus thing went away. Any ideas what could cause the OBD not to read and no bus to flash?
Old Oct 27, 2021 | 07:40 PM
magnethead's Avatar
magnethead
You shorted one of the comms wires to ground, which freaked out all the modules (CTM, Radio, Airbag, Cluster).
Old Oct 28, 2021 | 08:44 AM
Ally2332's Avatar
Ally2332
How do I fix it?
Old Oct 30, 2021 | 01:48 PM
magnethead's Avatar
magnethead
does it only do it when you plug something in the ODB port?
Old Oct 31, 2021 | 12:47 AM
hidden1's Avatar
hidden1
Maybe replace the entire obd2 connector an wires, an splice as far back on wiring you can get..then retest .
Old Nov 12, 2021 | 04:55 PM
Ally2332's Avatar
Ally2332
yeah. Everything is fine s long s nothings plugged in
Old Nov 12, 2021 | 04:57 PM
Ally2332's Avatar
Ally2332
I’ll try that. There is also a orange and black wire with a connector on it that comes off of the OBD wires that looks like it should plug in somewhere. Any idea what it’s for?
