98 Dakota follow up
Old Aug 13, 2022 | 03:46 PM
Bounty37716's Avatar
Bounty37716
Default 98 Dakota follow up
In a follow up from yesterday I found where the lines should go but where do they come off of the intake?
I am pretty sure this is most of the problem
Old Aug 13, 2022 | 07:31 PM
supadoom's Avatar
supadoom
There should be a plastic tube coming off the intake under the throttle body. I don't know what side but it should be easy to spot. You can buy some rubber tubing at a parts house and run it over. I don't remember where the right most line is supposed to connect. Look around and see if you can find any spots.
