Remote entry
Old Jan 7, 2006 | 12:10 AM
wejaz28's Avatar
wejaz28
Default Remote entry
Just bought a 1999 Dakota. It came with 2 remotes, but neither one works (replaced the batteries). Can someone tell me who to program them to see if they work?
Thanks Weja
Old Jan 13, 2006 | 01:27 PM
andycole1's Avatar
andycole1
Default RE: Remote entry
GET READY THIS HAS 12 STEPS
NOTE: WHEN ENTERING PROGRAM MODE USING FOB, ALL OTHER PROGRAMMED FOBS WILL BE ERASED AND YOU WILL HAVE TO REPROGRAM THEM FOR YOUR VEHICLE
1. ENTER YOUR TRUCK AND CLOSE ALL DOORS
2. PUT ON YOUR SEAT BELT SO THE SEAT BELT BUZZER DOES'T CONFUSE YOU WITH THE CHIMING YOU WANT TO HEAR
3. PLACE THE KEY IN THE IGNITION
4. TURN THE KEY TO THE ON POSITION BUT DO NOT START
5. PRESS AND HOLD THE UNLOCK BUTTON ON THE KEY FOB
6. HOLD THE UNLOCK BUTTON FOR 4 SEC. NOW ALSO HOLD THE PANIC BUTTON
7. RELEASE BOTH BUTTONS AND A SINGLE CHIME WILL BE HEARD THIS INDICATION THAT YOU HAVE SUCCESSFULLY ENTERED PROGRAM MODE. ALL FOBS THAT ARE TO BE PROGRAMMED MUST BE DONE SO WITHIN 30 SEC. OF WHEN THE CHIME WAS HEARD.
8. USING THE FOB TO BE PROGRAMMED PRESS AND RELEASE BOTH THE LOCK AND UNLOCK BUTTONS, SIMULTANEOUSLY.
9. A SINGLE CHIME WILL BE HEARD
10. WITHIN FOUR SECONDS OF HEARING THE CHIME PRESS AND RELEASE EITHER THE LOCK OR UNLOCK BUTTON ON THE FOB.
11. REPEAT STEPS 8 - 10 TO PROGRAM UP TO TWO ADDITIONAL FOBS.
12. YOUR TRUCK WILL REMAIN IN PROGRAM MODE UP TO 30 SEC FROM WHEN THE ORIGINAL CHIME WAS HEARD. AFTER 30 SEC. ALL PROGRAMMED FOBS FUNCTION NORMALLY.
GOOD LUCK
