Transmission cooler/power steering O-ring help
Old Dec 14, 2023 | 07:43 AM
BoogerSchultze's Avatar
BoogerSchultze
Default Transmission cooler/power steering O-ring help
2001 dakota sport, ext cab, 3.9, rwd.
I need to replace the o-rings for the transmission cooler lines going into the radiator, they're old and leaking. I read on here that they're "#11 5/16 ID" but i need to know the o.d. The simple google search gives too much unreliable info. I also need the o ring sizes for the fittings going into the power steering pump, it's leaking at both pieces for the high pressure.
Tia
Old Dec 18, 2023 | 09:50 PM
magnethead's Avatar
magnethead
Believe both will be the #11 - standard 7/16 x 5/16. But the power steering might be a #12 1/2 x 3/8. Not 100% sure off hand.
https://www.allorings.com/O-Ring-AS5...ard-Size-Chart
Old Dec 18, 2023 | 10:39 PM
Oliver Geroge's Avatar
Oliver Geroge
Tia
For the transmission cooler lines going into the radiator, the #11 o-rings usually have an outer diameter (O.D.) of around 1/2 inch or roughly 0.5 inches.Regarding the power steering pump fittings. Typically, those o-rings could have an inner diameter (I.D.) of around 5/16 inch and an outer diameter (O.D.) of approximately 1/2 inch.
