Door Panels
Old Jan 11, 2006 | 12:41 PM
earasta's Avatar
earasta
Default Door Panels
Hi guys looking for a rear right door panel for a 200 quad cab. According to the dealer these are discontinued. What I really need is the door handle for the inside, the clip broke so that door can only be opened from the outside andthe dealer said I would have to replace the entiire panel. Is there anywhere selling replacement panels?
Old Jan 14, 2006 | 12:07 AM
BlackDak07's Avatar
BlackDak07
Default RE: Door Panels
i think i had the same problem as you...was it a little clip that connects the rod to the door handle?? if it is then what the dealer told to is BS. you dont need the whole door pannel, just ask them if they have the clip...i asked them and they just gave one to me that they had just laying around off a spare handle. wost comes to worse you will have to buy a new inner handle and its about $30.
Old Jan 14, 2006 | 11:51 PM
earasta's Avatar
earasta
Actually if you are refering to that white clip that goes donwn into the hole connecting the rod to the actual handle, I have that clip, however the hole on the actual handle was busted apart breaking that section of the handle so there is no area to put that clip into. So I guess I need just that inner handle mechanism, but the dealer said it does not come seperate it is part of the panel.
Old Jan 15, 2006 | 02:58 AM
BlackDak07's Avatar
BlackDak07
oh ok i had the same problem then.....i forgot to menchin that when i was trying to put that little clip on i broke the hole it goes into so i had to buy a new inner door mech.. i dont know about the year of your but for mine i could buy it without buying the whole door pannel and it was $30
Old Jan 15, 2006 | 02:50 PM
earasta's Avatar
earasta
That,s exactly what happen to me. So this is called inner door mechanism? I have a 2000 dakota
Old Jan 15, 2006 | 02:52 PM
BlackDak07's Avatar
BlackDak07
ya im pretty sure
