trans wont shift.....
Old Feb 17, 2006 | 02:30 AM
imavirusforu's Avatar
imavirusforu
Default trans wont shift.....
when i punch it at 0 or 20mph it wont shift from 1st to 2nd i have to left off and then hit it again or the motor will just redline back and forth???? wut can i do to stop that.....i thought a programmer would help that but i didnt it just made it redline at a higher rpm.
Old Feb 17, 2006 | 04:27 AM
cool dakota's Avatar
cool dakota
Default RE: trans wont shift.....
Check the fluid. Change it if dark in color. Also check to see if the detent cable is attached. I can't remember if there is a vaccum operated shifting module for that tranny.
I would first check the fluid and make sure it is bright in color. If dirty looking change it. That will cause it to act up too.
Gool luck....
Cool dakota
Old Feb 17, 2006 | 04:52 AM
horatio102's Avatar
horatio102
Mine does the same thing. Annoying.
