Vacuum Line Question
Old Feb 22, 2006 | 01:15 PM
tlindell's Avatar
tlindell
Default Vacuum Line Question
I have just reinstalled a rebuilt 3.9L V6 for my 1994 Dakota. I two vacuum lines that I cannot find a home for! One is very small and comes out of the fire wall just below the heater hoses. The other T's off the line that comes out of the middle of the intake manifold on the right side. One half goes back to the fire wall and I have that connected. The other half, is a smaller hose, goes towards the front of the manifold. Any help will be greatly appreciated.
Old Feb 27, 2006 | 11:42 PM
28this's Avatar
28this
Default RE: Vacuum Line Question
Can you take a pic and post it? I may know , but I want to make sure so I don't confuse you or myself.
Old Feb 28, 2006 | 02:07 AM
stantheman's Avatar
stantheman
there are a couple of tbues on either side of your intake close to the bottom in the middle. if you havent already got those im not sure.
Old Feb 28, 2006 | 02:08 AM
stantheman's Avatar
stantheman
also check around your throttle body, its too dark out to go check mine at the moment
Old Mar 3, 2006 | 01:27 PM
tlindell's Avatar
tlindell
Thanks for your input. I got it figured out by looking at pics I took at the beginning of the project that I forgot I took. The larger of the hoses was actually supposed to run to the back of the intake and the smaller hose actually fit inside of it. Still not sure what it does, but at least it is connected.
Now I have to take the intake off to replace a leaking gasket! [:@]
