HeadLight Trouble
Old Feb 27, 2006 | 08:40 PM
batman13's Avatar
batman13
Default HeadLight Trouble
Does anybody know where I can find cheap headlight housings? I blew a bulb on one side and replaced it fine, but when I got to the right side I discovered so much damage behind the light that I can't get the bulb out and my corner lens is held on by a couple clips,{S#!t} All the damage can be fixed easy thanks to an uncle who is a bodyman at a local dodge dealer. But I don't have much money to upgrade yet so I need a cheap housing for now.
97' Dak
________
E-CIGARETTES
Old Feb 27, 2006 | 09:12 PM
28this's Avatar
28this
Default RE: HeadLight Trouble
Cant hurt to check your local junk yard. Are you looking for the headlight lens or are you looking for the marker light lenses or both? Ebay would be another place to look. You can find oem and aftermarket there.
Old Feb 27, 2006 | 09:38 PM
batman13's Avatar
batman13
I need both, there's chunks of plastic missing. The entire housing's gonna need to be replaced after I get the steel behind it straightened out
Being an unpredictable winter up here I like to keep my truck in good running order and I hate problems.
________
Wellbutrin lawsuit information
Old Feb 27, 2006 | 09:48 PM
28this's Avatar
28this
Headlight and Marker Light Assembly
I found this link above. It shows you can get the whole front assembly, markerlights and headlights.
Old Feb 27, 2006 | 09:56 PM
batman13's Avatar
batman13
Thanks, I appreciate the help, I'll check the grave-yard first. Tomorrow
________
MisteriousMilf cam
