rev's going down when turning the wheel...
Sep 1, 2006 | 06:08 PM
RE: rev's going down when turning the wheel...
a leaking power steering line
Sep 1, 2006 | 06:09 PM
or steering box or pump
since the pump has been cavitating like you are describing
Sep 1, 2006 | 06:10 PM
you should have power steering pump problems in the future
therefore I reccomend changing the pump while your at it.
Sep 1, 2006 | 06:11 PM
I highly reccomend bleeding the power steering system when part is intalled per AGR Performance instructions
Sep 1, 2006 | 06:12 PM
This will prolong your power steering pumps life
Sep 1, 2006 | 06:13 PM
I also recommend using redline synthetic power steering fluid
This fluid is simply the best for the power steering systems life and performance.
Sep 1, 2006 | 06:14 PM
And don't use ATF it simply doesn't have the same lubrication properties when hot that power steering fluid has.
