lug nut size
Old Apr 14, 2006 | 01:06 PM
dpoliver's Avatar
dpoliver
Default lug nut size
Turns out nuts mine are just nuts with a foil cover...
they look real enough till you rip them apart....
what size are they?....
thx
Old Apr 15, 2006 | 01:40 AM
horatio102's Avatar
horatio102
Default RE: lug nut size
iirc 3/4" or 19mm, depending on which way you swing.
I've got two lugs minus the foil covers. Big deal.
Old Apr 19, 2006 | 10:17 AM
stu's Avatar
stu
Ha! I got three on mine. That's from the mechanic using the impact gun on them and then when I went to rotate the wheels three of them tore. I didn't know at the time they were just covers. I used a nut removing socket to remove them. Cheap, Cheap design.
stu
