abs and brake light
Old Apr 16, 2006 | 12:45 AM
stevegeddes's Avatar
stevegeddes
Default abs and brake light
Today, the abs and brake light came on the instrument panel and won't go off. The owners manual says to "get to a mechanic immediately." Suggestions on possible fixes - such as clearing a code to see if this fixes it - or do I really have a problem?
Old May 18, 2006 | 09:43 PM
GangstaHic's Avatar
GangstaHic
Default RE: abs and brake light
I had the same problem on my dakota also
I fixed it my putting the truck in park (while on) and engage the parking break and then disengage it
After that the 2 lights went away.
Hope it helps
Old May 19, 2006 | 01:19 AM
nomagination's Avatar
nomagination
Same thing happened to my truck. Replace the wheel speed sensor on the top of the rear end housing. Part is aobut $35 at the dealer and easy to do yourself. No special tools required.
Old May 20, 2006 | 03:50 AM
MikeRT98's Avatar
MikeRT98
yeah mine does this too. it comes and goes intermittingly. i should look into that sensor cuz my speedometer is all messed up too (anywhere from 5-15 mph off and i have stcok gears and tires)
Old May 25, 2006 | 12:36 AM
marks99dak's Avatar
marks99dak
have you inspected your brakes mine did it when i changed my brakes
Old Jun 4, 2006 | 11:45 PM
mrcowboy32's Avatar
mrcowboy32
just had the same prob. right on the 3rd member where the speed control sensor mounts , leave the sensor in but there is a conector going from the wires on the sensor to the wires from the harness , you can remove this 8 inch section with no tools and you may find that you have lost connection at the conectors i repaired mine my self ,part runs 50 bucks ,light comes on when open circuit is detected
Old Jun 9, 2006 | 04:30 AM
nomagination
If your connections are good, replace the sensor. If the sensor's bad, your speedometer won't work until you get to 35 mph and you'll have the brake and ABS lights. Also, if you have power door locks, the auto lock feature won't work until the speedometer kicks on.
Old Jun 22, 2006 | 12:25 PM
mjcibor's Avatar
mjcibor
i have the same two lights on but my speedo works fine. would that suggest it's not the sensor and i have some other problem? thanks.
Old Jun 27, 2006 | 09:12 PM
cTak's Avatar
cTak
I have the exact same issue, both lights on, but everything works (speedo, odo, cruise, etc)
Old Jun 27, 2006 | 09:15 PM
iversonformvp's Avatar
iversonformvp
i am having the problem it seems like every third start.
What happens is that the abs and brake light are on.
But when my the abs/parking light is on the speedometer, radio, windows, windshield wiper, did not work. I have no idea what is going on.
The time that the abs and parking brake light does not come on everything works just fine.
Thanks for any help
