99 v-6 no start
Old May 4, 2006 | 02:14 AM
jm ray's Avatar
jm ray
Default 99 v-6 no start
i have a no start on a 1999 dakota.it has no codes, great spark,and 50 psi of fuel pressure, but refuses to start. it will not even run if you pour gas into it. anyone have a guess? seems to have good compression and in time.
Old May 4, 2006 | 04:04 PM
stantheman's Avatar
stantheman
Default RE: 99 v-6 no start
sounds like pcm problem that ive run across before. the problem was the pcm was not communicating with the asd relay. so therefore the asd relay is engaged. might want to take it to a dealer to see if it is the pcm.
