Reverse Lights Problem
Old May 18, 2006 | 07:47 AM
mnvikingsfreak's Avatar
mnvikingsfreak
Default Reverse Lights Problem
does anyone know what could be causing my reverse "backup" lights not too work?? I checked the fuses and they are all good and replaced both bulbs with new ones I have heard it could be the tranny safety switch is off? I have a 2000 dakota 3.9
thanks for your time
Old May 18, 2006 | 02:35 PM
horatio102's Avatar
horatio102
Default RE: Reverse Lights Problem
When that happened to my old Jetta it was a melted wire harness on the tranny (from the reverse switch). I'd start by looking at wires, fuses, and the switch on the tranny itself.
Old May 20, 2006 | 05:55 AM
28this's Avatar
28this
The reverse switch is also known as a neutral safety switch. If it is not positioned right, it will not activate the reverse lights. Hopefully it is this, because it is a simple adjustment to fix.
