High nitrogen count during MD emission test
Old May 24, 2006 | 10:52 AM
LONG486's Avatar
LONG486
Default High nitrogen count during MD emission test
I have 99 Dakota that has failed Maryland emission test 4 times due a high nitrogen count. I registered a count of 36483 GPM and the cut off is 2600GPM. Does any one have some input on why this is so high? Any help would be appreciated. Thanks.
Old May 25, 2006 | 11:15 PM
Ken's Avatar
Ken
Default RE: High nitrogen count during MD emission test
Oxides of Nitrogen (NoX) are usually created by overly high cylinder temperatures during combustion. Generally speaking, EGR problems are a major cause of high levels of NoX. One of the problems that occurs on Magnum engines is the clogging of the EGR port passage inside the intake manifold. What happens is: When the engine controller allows exhaust gasses to re-enter the intake (exhaust gas recirculation), it reduces the amount of fuel through the injectors. This is because EGR gas is inert; it doesnt help the burn in any way. If inert gas takes up, say, 10% of the volume in a cylinder, you'd need to reduce fuel by 10% to keep the proper mixture. If the inert gas doesnt get there, the fuel mixture is too lean; the major cause of high combustion temp.
I really think you need to get to a shop or dealer that can accurately monitor the PCM. The Chrysler DRB3 can actuate the EGR system, which should make the truck stall if done at Idle. If it doesn't stall, either the valve isn't opening, or the passage is gummed up.
Here in MA, we also have the IM240-style emissions testing. There is a list of qualified service centers that are state-approved to make emissions repairs. If you spend a certain amount at one of these shops, and your car still doesnt pass, you get a waiver. If you go to a shop not on the state's list, you get no waiver no matter how much you spend. Choose your shop wisely, and read the info they gave you with the rejection sticker. There's usually some good info there.
Old May 26, 2006 | 09:09 AM
Robertwav1's Avatar
Robertwav1
ORIGINAL: Ken
Nice write up there Ken! I use "autotap" software for troubleshooting problems, good graphs etc. Most important are the things like you mention here....all part of the equation.
Old May 26, 2006 | 06:58 PM
osteodoc08's Avatar
osteodoc08
Check your warranty, I think there is a specific emissions warranty pertaining to emissions testing/failure. Most likely it is the EGR valve or system causing the problem.
**Edit**
Nevermind, only the PCM and cats are covered to 80K miles. Everything else is the 3/36.
