Coolant Leak - question
Old Jul 11, 2006 | 09:57 PM
lil's Avatar
lil
Default RE: Coolant Leak - question
I had a car in high school that the thermostat got stuck closed and it caused a freeze plug to blow and engine to over heat because when it gets stuck closed all the pressure builds in the block.....I think you might be on the right track
Old Jul 12, 2006 | 12:03 AM
jeff_rt's Avatar
jeff_rt
Thanks for the info LIL. I appreciate your input.
I'll probably end up replacing it and if that doesn't fix it, then off to the shop.
Old Jul 12, 2006 | 04:10 PM
jeff_rt's Avatar
jeff_rt
Default RE: Coolant Leak - answer
Root cause was the thermostat. I just finished putting
the new one in, refilling and gave it a rigorous test drive.
Temperature is fine.
Thanks everybody for your assistance. I probably saved $3-400
with your help.
