Heater/AC blower doesn't work..
Old Jul 23, 2006 | 06:08 PM
Jerrysteenhoek's Avatar
Jerrysteenhoek
Default Heater/AC blower doesn't work..
2004 Dakota, the blower doesn't work in any switch position. I have replaced the blower resistor, to no avail. The AC still works (as cold air will gently flow through the vents at highway speed w/the AC on). I have checked the underdash fuses, they are OK. Am I missing any simple repair, or is this a switch/control issue. (If so, what is the swich replacement procedure?)
Thanks!
Jerry
Old Jul 23, 2006 | 06:24 PM
dodgerules86's Avatar
dodgerules86
Default RE: Heater/AC blower doesn't work..
Is the resistor getting juice?
Old Aug 23, 2006 | 01:05 PM
ehtruck's Avatar
ehtruck
Have you been able to find a solution? I joined this forum for this exact problem. All the fuses look good. I tested the power at the switch and it appears to be too low so I need to find the power loss before that point, but I don't know where to trace the wires to. Anyone know?
thanks
Old Sep 15, 2006 | 08:36 PM
Glennson600's Avatar
Glennson600
I had the same issue on my '04 with 31,000 miles,with out a shadow of a doubt it IS the Blower Resistor. I do not know the charge because it was covered under warranty. Hope this helps.
Old Sep 16, 2006 | 07:31 AM
dodgerules86
I believe the blower resistor is around $10.
As far as tracing wires, go HERE and download the service manual. It like 80-or-so megabytes, but, its a lot of great information. Its a manual for a 2001, but it should apply to other years as well, for the most part.
