Door panels
Old Aug 30, 2006 | 06:34 AM
fyrfyghtr's Avatar
fyrfyghtr
Default Door panels
I have blown speakers in the front door panels. I need to get the door panels off to get at the speakers. What is the best way to get them off without damaging them?
Old Aug 30, 2006 | 07:06 AM
RP Racing940's Avatar
RP Racing940
Default RE: Door panels
should be 2 screws in the door pull, 1 in the upper corner where near the side mirror, one in teh door handle plate and I think there might be 2 at the bottom (double check). After all the screws are off, pull the power door lock/window switch plate out and disconnect (ifapplicle) or the window crank. Slowly lift straight up on the door panel and you should be able to disconnect the door handle from teh panel and then remove it totally. Just take your time and look at how the door sits. Usually its pretty obvious on how the door comes off. Dont have my manual handy or I could go word for word.
Old Aug 30, 2006 | 07:47 AM
fyrfyghtr's Avatar
fyrfyghtr
Thanks RP.
