2000 rwd rear axle question
Old Sep 1, 2006 | 04:22 PM
dolbnyc's Avatar
dolbnyc
Default 2000 rwd rear axle question
Are there different Axle shaft Lenghts for the 9.25 inch rear
this truck spun out, and broke the rear wheel.
the reason i ask is because 1 wheel protrudes 1 inch on one side was thinking either they put a different shaft in
or maybe there are longer shafts in the wheel studs, I will measure from the backing plates when I pull the wheels
the body is strait, and the bed is even
just wondering
if a 4wd shaft would be longer than the 2wd and that would be causing this
