hissing noise
Old Sep 6, 2006 | 11:28 PM
mjmartinez's Avatar
mjmartinez
Default hissing noise
2001 dodge dakota quad cab 4.8 engine 4x4 - I have noticed in the past few months of a hissing noise coming from under the hood regardless if I am in neutral or drive. I have checked for leaks in hoses but haven't found anything. I am not losing power and gas mileage is the same. Any ideas on what it may be.
Old Sep 7, 2006 | 12:54 AM
OldDodgeDriver's Avatar
OldDodgeDriver
Default RE: hissing noise
I've had luck with a 3' length of garden hose. One end to your ear and the other end pointed at possible sources of the hissing: vacuum hoses and connections, intake gaskets, etc. Just be careful of moving things like belts and fans and hot things like exhaust! [sm=signs003.gif]
Old Sep 13, 2006 | 07:33 PM
Kieson17's Avatar
Kieson17
I noticed the same thing on my 02 dakota and I was told that it was just water hitting the exhaust pipe. I was also told that it was from running the air conditioning. Try not running the air conditioning and see if the hissing is still there. Good Luck
Old Sep 13, 2006 | 08:49 PM
Chris's Avatar
Chris
could definately be a leak in your lines coming from your ac compressor.
Old Oct 1, 2006 | 10:19 PM
mcfattyfatfat's Avatar
mcfattyfatfat
I am experiencing similar problems with hissing coming from the engine compartment. I cannot see any water or anything dripping on the manifolds. The sound also occurs regardless if the A/C or Defrost is on.
The sound is very noticeable and loud, it starts out intermittent and then eventually continues.
Is there any possibility it being an exhaust leak, or even worse a head leak!!!!
Thanks for any comments.
Old Oct 2, 2006 | 08:20 AM
rhowe's Avatar
rhowe
I have an 2001 v6 that started hissing just a week or two ago. i haven't looked for it cause my exhuast is also getting to be quite loud, but it seems loudest when its first started and when i'm on the gas/clutch. i know its not water dripping and i'm pretty sure it doesn't have to do with th ac cause i haven't used it for a xouple weeks. better not be a gasket!!!
Old Oct 9, 2006 | 02:43 AM
cleverusername's Avatar
cleverusername
i have what appears to be a hissing noise as well. pokin around and listening with my steathascope the sound is comming from my power stearing pump. i don't think its bad, maybe its on its way but its been there for 4mo now with no noticable changes in driveability. check it out.
