heater
Old Sep 25, 2006 | 09:22 PM
santeemtbkr's Avatar
santeemtbkr
Default heater
hopefully someone can help..when i turn the heater on it only blows cold air.ac works fine just no hot air. any thoughts of what it might be?
Old Sep 25, 2006 | 09:53 PM
Twiztid's Avatar
Twiztid
Default RE: heater
Could be a few things, low coolant/bad stat, bad switch that controls the door between hot and cold, or maybe the door itself has gone bad. Sounds as if your fan is fine since it blows cold. I would first check your coolant level and stat.since they are the easiest. Not sure hwo to check the switch/door without just replacing them, maybe some sort of voltameter do hicky.
Chris's Avatar
Chris
Default RE: heater
have you experienced water/coolant inside of the cab? it could be your heater core, or inlet valve.
Old Sep 26, 2006 | 10:54 PM
Mean Green's Avatar
Mean Green
Default RE: heater
It may just be clogged if you aren't having any overheating issues. Check this thread out for instructions on how to take care of it. https://dodgeforum.com/m_568926/tm.htm
Old Sep 28, 2006 | 12:07 AM
santeemtbkr
Default RE: heater
thermostat is new, water pump is new, no sign of coolant inside of cab. how do you tell if the heater core is bad?
Old Sep 28, 2006 | 01:26 AM
Mean Green's Avatar
Mean Green
Default RE: heater
Your heater core is most likely clogged follow the link I left in my previous post and it will tell you how to flush it out. Your heater core would be bad if that flush does not work or if it is leaking in which case you would have coolant on the passenger side floor and just so you know everything is the same between the dakota and durango from the cab forward.
Old Sep 28, 2006 | 02:41 AM
santeemtbkr
Default RE: heater
thanks for the info i will try to flush the heater core this weekend and hopefully this will fix it.
Old Sep 28, 2006 | 02:54 AM
Mean Green's Avatar
Mean Green
Default RE: heater
Let us know how it goes.
Old Oct 9, 2006 | 03:22 AM
santeemtbkr
Default RE: heater
ok i back flushed the heater core. I ran water backwards thru the heater core for about 5 mins. then i ran it thru the normal way for 5 mins. I did that twice both ways and now i've got heat. Thanks for the help..
Old Oct 9, 2006 | 04:10 AM
sgt_duffy's Avatar
sgt_duffy
Default RE: heater
Hey, I have the same problem every year. The heater core becomes clogged and needs to be flushed, but not the normal flush. Water needs to be back flushed in order to really make it effective. When does this way it is very effective and save the 500 bucks for a new heater core....
DJ
