underpowered
Old Oct 5, 2006 | 02:09 PM
Chris's Avatar
Chris
Default RE: underpowered
ORIGINAL: f0x672
wastegate aka blow off valve
wastegate and blowoff valves are two different things completely.
horatio beat me to it. you salty dog!
Old Oct 5, 2006 | 07:12 PM
skytja's Avatar
skytja
Turbos do lag, because they are driven by the exhaust.
more exhaust=faster spinning turbo=faster spool-up.
This is why most turbos are sized to kick-into boost at higher RPMs.
Don't want them kicking in just-off idle.
Larger engines like the 5.2 and 5.9's, that already have a good bottom-end grunt typically don't see a big problem with turbo-lag, just a harder kick when the turbo kicks-in. Yes, that's still lag, but not in the same way as the old 2.2 or 2.4L daytonas that didn't have the bottom-end to begin with.
If you work-out the math, you can size the turbo(s) and collector(s) to have the boost kick-in at whatever RPM you want.
As for me, Math Bad.
Old Oct 6, 2006 | 12:11 AM
Minion's Avatar
Minion
i wnat my truck to spin the tires when i floor it. now i just accelerate fast. it had for my to break my tires loose on regular roads, and do know what im doing.
Old Oct 6, 2006 | 01:45 AM
jnellydodge's Avatar
jnellydodge
ORIGINAL: Minion
You have a 98' dakota 4x2 with the 5.9 and it wont chirp the tires??? My 98' 5.2 dakota 4x4 club cab would roast em' all day if i wanted to, and that's with extra wide Khumo tires. Heck i could be going 10 mph around town and take a corner and floor it and she would kick sideways. I loved driveing that truck, it would walk all over my ram in a race, if there is any sense to race 4x4's.....although my dakota would keep up to my buddies 01 silverado 5.3 till about 40-50 mph, i was proud of that little truck maybe something is wrong with yours???
Old Oct 6, 2006 | 01:50 AM
Minion's Avatar
Minion
ive spun them twice once was arround a cornor, and the other time some gravel was involed then turned into road. i can skeak them sometiems but not whenever i want
Old Oct 6, 2006 | 02:50 AM
jonnymagnum's Avatar
jonnymagnum
my truck has 201,000 kms on it and it will break the tires loose all day long. I can leave a stop light and give her a lil bit of gas and chirp the tires. I can go around corners sideways, and be crusin around 40-50 kms and step on it and the tires will break loose. and in the rain my truck is stupid, I broke them loose once trying to pass someone on the highway. maybe your truck just needs a tuneup.
________
MOTORCYCLE TIRES
Old Oct 6, 2006 | 05:17 AM
horatio102's Avatar
horatio102
I'm going to assume that he's got a quad cab like I do, except in 2wd. The quads seem to have a lot more weight over the rear axle. Also all of the 5.9's are autos.
On wet my truck will light up a tire all day long, but on dry it just sticks and goes.
Old Oct 8, 2006 | 07:39 PM
Minion's Avatar
Minion
its a club cab i found out ove rthe weekend i can go around a cornor and break them loose and slide arround the cornor. lots of fun
Old Oct 8, 2006 | 07:46 PM
RP Racing940's Avatar
RP Racing940
Gee I can break the tires on my 3.9 loose at 25mph with just the gas.
Old Oct 9, 2006 | 01:45 AM
superdak05's Avatar
superdak05
if you want 300 plus power at the wheels, take the motor out spend 2000.00 and stroke it to a 408. this kit is killer. most mustang gts cant hang with this set up. get in touch with www.krcperformance.com and they have all these 360/408 motors already done up and dynoed on there web site. i can tell you i got a set of 206 cams for my 05 4.7 and what a big differece it made.
