I'm getting error code 051 any help?
I don't think double digit codes have been used since like 95 when OBD I was still being used by automakers. An OBD II (that is On Board Diagnostics version 2) code should look like P0441 or atleast a letter with 4 digits following it. Go to AutoZone and borrow their scanner then right down the code exactly as it appears. There is a sticky at the top of this forum labeled Check Engine Codes, it should help you out. Good Luck, welcome to the forum.
