corner lenses
Old Oct 11, 2006 | 10:17 PM
Jhop16's Avatar
Jhop16
Default corner lenses
i baught some clear corner lenses, they replace the amber signal in the front... anyways... i cant figure out how to get the dam lights off, the lights didnt come with very good instructions... is there a easy way to do it? or od i need to take my hole light off?
Old Oct 11, 2006 | 10:24 PM
f0x672's Avatar
f0x672
Default RE: corner lenses
there should be a screw inbetween the actual head light and the amber light.... and then you can pop it off.. that should be it.. dont be afraid to work it a bit
Old Oct 11, 2006 | 10:48 PM
Chris's Avatar
Chris
you will need a small hex ended bit or screwdriver to be able to remove the screw.
Old Oct 13, 2006 | 11:53 AM
02dakotakid's Avatar
02dakotakid
also dont be surprised if you have to cut and wire the new ones... theres only two wires though so it should be easy
