Slippage
Old Oct 13, 2006 | 04:27 AM
RJTDakotaBoy's Avatar
RJTDakotaBoy
Default Slippage
So I was driving home from my girlfriend's house tonight and when I shifted into Drive, my truck stayed in neutral then hit drive. As I drove it was shifting very hard and then the tranny started to slip. I pulled over and put it in park and waited a second then shifted into drive again and drove the rest of the way home and it was perfectly fine. I just had my diffs serviced (180 000 kms) so I am wondering if that had anything to do with it. BTW my truck is a 2000 Dakota with a 4.7 L on a 4 speed.
Any Advice??? Greatly appreciated!
Old Oct 13, 2006 | 06:49 AM
dodgerules86's Avatar
dodgerules86
Default RE: Slippage
Just curious, is the transmission fluid at the proper level? (Proper way to check: get the engine and transmission to operating temp. With the truck parked on a level surface, and the engine running, shift the transmission from park, thru all the gears [P to R to N to D] and back into neutral. Apply parking brake, and check the transmission fluid) Add only ATF+4 fluid and do NOT overfill!
Old Oct 13, 2006 | 01:27 PM
Chris's Avatar
Chris
ORIGINAL: dodgerules86
sounds like a fluid level for sure.
Old Oct 13, 2006 | 01:35 PM
RJTDakotaBoy
Ok well I'll check and hopefully that;s it. Thanks guys!
Old Oct 13, 2006 | 07:39 PM
f0x672's Avatar
f0x672
yea my trans begins to lose gear whenever im going around turns.. and its at the right fluid level.... i just dont get it..... let alone the god damn solenoid pack doesnt let the trans to shift from first to second with WOT.... i hate dodge transmissions... time to shove allisons into these things
Old Oct 13, 2006 | 11:50 PM
RJTDakotaBoy
I second the motion... these Mopar transmissions are not exactly the Bee's Knees...they are more of a snake on my plane
