2" body lift
Old Nov 21, 2006 | 03:17 AM
Rakaric's Avatar
Rakaric
Default 2" body lift
Hey I was wondering if I should get a body lift kit, just only about 2 inches. Where can I get it cheap? And also, what would the after effects be after installing it? Will there be any complications during the procedure?
Old Nov 21, 2006 | 05:13 PM
Chris's Avatar
Chris
Default RE: 2" body lift
it is a pain in the ***, but a manageable job. you just need to ask yourself if you plan on doing a lot of offroading or not. if you do plan to, go with a suspension lift, not a body lift.
Old Nov 21, 2006 | 05:16 PM
Rakaric's Avatar
Rakaric
yea i know. I realize that body lift only really lift the body, but give no ground clearance. I just wanna get a good deal for cosmetics use.
Old Nov 21, 2006 | 07:48 PM
Chris's Avatar
Chris
then if that is the case, you can find 2-3" body lifts all voer ebay for almost every year dakota between $220-$300.
Old Nov 21, 2006 | 07:56 PM
Rakaric's Avatar
Rakaric
okie dokie. well i found that 97-99 is cheaper than 00-02. Why would that be? I would assume they're the same from 97-04
Old Nov 22, 2006 | 03:06 PM
Chris's Avatar
Chris
could be something as simple as supply and demand. [:@]
