+ battery connector stuck
Old Nov 28, 2006 | 05:50 PM
varsis's Avatar
varsis
Default + battery connector stuck
I can't seem to get off my postive battery connector which I am trying to do because I would like to reset my RAM in my truck but I can't get it off as it is rusted so bad. I losened the nut and no go tried to pry it apart no go.
Chris
Old Nov 28, 2006 | 06:19 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: + battery connector stuck
try either prying on it with a screw driver or put vise grips on it to loosen it off.
________
Vaporizer Affiliates
Old Nov 28, 2006 | 06:28 PM
Chris's Avatar
Chris
if the positive terminal is rusted/corroded that bad, you should replace the positive terminal all together. you can get a new terminal for less than $10 at any auto parts store. be sure to pick up some of the protective grease to prevent/slow down future corrosion.
Old Nov 28, 2006 | 06:30 PM
Chris's Avatar
Chris
you can always give the terminal (not the battery) a kind whack with a small hammer to "pursuade" it a little.
Old Nov 28, 2006 | 10:55 PM
Minion's Avatar
Minion
terminal puller they do accually make them, then clean in really well
Old Nov 29, 2006 | 07:28 AM
rhowe's Avatar
rhowe
just do it!! put some m and m (muscle and mind) behind it... you can do it................................................
