stripped front driveshaft flange bolts?
Old Dec 7, 2006 | 01:12 PM
Erich_121's Avatar
Erich_121
Default stripped front driveshaft flange bolts?
while trying to change the u-joints i stripped a bolt that is on the flange of the double cardan assembaly. Its pretty tight in there and i dont know how to get it off. Any ideas??
Old Dec 7, 2006 | 04:14 PM
kurbycar32's Avatar
kurbycar32
Default RE: stripped front driveshaft flange bolts?
they make tools for that. i have a socket that is filled with these long pins that will grab even a round stud, i got it at harbor freight for like $15. theres also these things that you can get at home depot or any good hardware store:
Old Dec 7, 2006 | 05:12 PM
Erich_121's Avatar
Erich_121
thanks alot!
Old Dec 8, 2006 | 12:47 AM
98Dodger4x4's Avatar
98Dodger4x4
they work wll i use them at work alot
Old Dec 8, 2006 | 04:36 PM
Ethica19's Avatar
Ethica19
I found the same ones at Sears, they work great on wheel locks when you loose the key or they break when they're sill on the stud!
