horn
Old Dec 17, 2006 | 06:02 PM
Rakaric's Avatar
Rakaric
Default horn
hey I got an air horn setup for my truck and I was wondering where the stock horn is located. Anyone know?
Old Dec 17, 2006 | 06:54 PM
RP Racing940's Avatar
RP Racing940
Default RE: horn
Look under the battery. Its either there or on teh otehr side of the truck near teh radiator area.
Old Dec 17, 2006 | 11:03 PM
Rakaric's Avatar
Rakaric
Default RE: horn
well i tapped the horn and figured it's somewhere by the battery. May I ask how does it look like?
Old Dec 17, 2006 | 11:23 PM
RP Racing940
Default RE: horn
A round black plastic. About 5 in in diameter and 1.5 in thick with an opening on one end.
Old Dec 17, 2006 | 11:28 PM
lil's Avatar
lil
Default RE: horn
If your is like my 03 and 04 there a 2 horns on the drivers side in front of the battery next to the head light, the connects can be reached from the front side by the radiator, we ran power from there across to the left side then mounted the dual air horns and compressor in front of the CAI pointing the open ends of the horns downward and bolting the horns and comprssor to the metal braces behind the access hole to the passenger's side head light, had this set up on my 03 when I traded it in so just had to disconnect the compressor and horns remove them and plug back in the stock horns took all of about 10 minutes and then installed them on the 04.....nothing nicer than air horns to wake up bad drivers.
Old Dec 18, 2006 | 02:42 PM
Rakaric's Avatar
Rakaric
Default RE: horn
Well I finally got em up. Apparently the horns were right in front of my face...it was right by the radiator on the driver's side. Took me a while to mount the horns and stuff. I also installed some running lights...tell me what you all think...
and how can i forget to post these?..
