Can't seem to get my windows wired properly
Old Dec 26, 2006 | 10:30 PM
red9535's Avatar
red9535
Default Can't seem to get my windows wired properly
I cant seem to get my windows wired properly. I can't get the drivers side switch for the passenger window AND the passenger side switch to be hooked up at the same time without causing a very noticable loss of power to both. If they are hooked up seperately and the other one isnt hooked into the motor, either one works perfectly. However, if I wire them both to the motor at the same time, then they don't work properly unless you hold them both down at the same time, regardless of if i actually wire the switches together, or if I send 4 wires out from the motor itself.. 2 for each switch.
Help please!
Thanks
I used the SPAL kit
