heater warm up
Old Jan 7, 2007 | 03:01 AM
hemiman07's Avatar
hemiman07
Default heater warm up
I have a 2000 quad cab 4.7, my question is about the heater. I've noticed now that it has been cold the heater takes quite a long time to get warm. About 15-20 min. The outside temp. in the mornings is about 35 degrees. Any help?
Old Jan 7, 2007 | 03:11 AM
dodgerules86's Avatar
dodgerules86
Default RE: heater warm up
But once it warms up, it blows hot air right?
If so, I would make sure the thermostat is working properly. If its stuck open, warm up times will increase a lot.
It also takes longer for it to warm up at idle than with the engine running as if you were driving it.
Old Jan 7, 2007 | 03:18 AM
hemiman07's Avatar
hemiman07
It doesn't blow hot, just warm. By the way I replaced the stock one about two years ago with a 180 degree one.
Old Jan 7, 2007 | 03:24 AM
dodgerules86
You might try flushing your heater core.
Old Jan 7, 2007 | 03:46 AM
hemiman07's Avatar
hemiman07
Thanks for the info.
Old Jan 7, 2007 | 05:17 AM
lil's Avatar
lil
Yeah something is wrong when it is 35-40F here I can start my truck in the morning and in 3-5 minutes I am getting hot air and in 10 minutes it is heating me out of the cab I have to turn down the blower from HI to Med/Low and turn the heat control down from HI to Med. or it over heats the cab and I am in a QuadCab.
Old Jan 15, 2007 | 12:03 PM
Erich_121's Avatar
Erich_121
You guys are lucky. Its 7 degrees here today.
