15x10 vs 15x8
Old Jan 10, 2007 | 10:14 PM
fastdak's Avatar
fastdak
Default 15x10 vs 15x8
i know this question has been asked but i just wanted to clarify it. if i was to do a body lift would i be able to fit 15x10 31x10.5x15 on a 2wd 01 dakota without rubbing i just like the way they look the 15x10s that is. sorry if this question has been asked i looked but couldnt come up with my answer i wanted.
Old Jan 10, 2007 | 10:22 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: 15x10 vs 15x8
how high are ya goin?
it should fit. I've seen 2wd dakotas with 32's with only a 3" lift.
Old Jan 10, 2007 | 10:24 PM
Chris's Avatar
Chris
Why do you want a 10" wide wheel? You can put 12.5" wide tires on an 8" wheel.
Old Jan 10, 2007 | 10:45 PM
dodgedakota98luver's Avatar
dodgedakota98luver
it eliminates that stuffed on the rim look. and makes your tire appear wider. i know a girl thats got 31x10.50's with 10 inch wide rims on a Chevy silverado. her tires look way wider than mine
Old Jan 10, 2007 | 11:09 PM
fastdak's Avatar
fastdak
i like the way wider tires look just the stance of it appeals to me. just wondering if 10" wide wheels will fit without rubbing i plan on adding a 3" body lift for now and maybe later on down the road add a 3" suspension lift but as of right now just the body lift. just wondering if this combo would work 31x10.50x15 on 15x10 wheel. will i rub or will be i ok. the wheels i want are eagle 058 BS 3 5/8. any ideas??
Old Jan 10, 2007 | 11:33 PM
imnothot02's Avatar
imnothot02
weeeeeellllllllllllllllllll whats the offset on the new rims..........
Old Jan 10, 2007 | 11:40 PM
fastdak's Avatar
fastdak
-46mm i believe
Old Jan 10, 2007 | 11:42 PM
fastdak's Avatar
fastdak
according to american eagle wheels website.
Old Jan 10, 2007 | 11:54 PM
DakotaMan's Avatar
DakotaMan
Fastdak are they the same rims i have bc if they are mine rubbed with 31x10.5 bad on a 15x8 rim
Old Jan 11, 2007 | 12:09 AM
fastdak's Avatar
fastdak
yeah i think they are but the ones i want are 10 and urs is 8 and the backspacing is a little different. yours are i think 3 1/4 and the 10s are 3 5/8
