loss of power
Old Jan 22, 2007 | 09:51 PM
zosdakota's Avatar
zosdakota
Default loss of power
I have a 97 dakota 3.9 that boggs down while I'm driving sometimes. It doesn't shut off but the rpms drop to about a grand and then regains power after a few seconds. What's up with that? Anyone?
Old Jan 22, 2007 | 10:03 PM
red9535's Avatar
red9535
Default RE: loss of power
It's generally referred to as shifting gears.
Old Jan 22, 2007 | 10:17 PM
zosdakota's Avatar
zosdakota
It's a 5speed. You got to come better than that.
Old Jan 22, 2007 | 10:53 PM
01dodgedriver's Avatar
01dodgedriver
it may be your idle speed actuator motor, try cleaning the throtle bodyw/ throttlecleaner. and if that doesnt work replace it.
Old Jan 22, 2007 | 10:57 PM
4x4kota's Avatar
4x4kota
It could possibly be the coil, but i doubt it, i'd gain access to a scanner and see if you can get any codes, it could be your TPS or other sensor.
Old Jan 23, 2007 | 02:34 PM
Chris's Avatar
Chris
Check battery terminal connections. Also, when was the last time you did a tune-up?
Old Jan 23, 2007 | 09:09 PM
steve05ram360's Avatar
steve05ram360
fuel pump... check fuel pressure and volume... being that it's intermittant, that may be hard to do.
Old Jan 23, 2007 | 11:15 PM
zosdakota's Avatar
zosdakota
I think I've got it. I changed the wires, plugs, cap, rotor,pcv,tps and theair intakecontrol valve. It seems to be okay now. Last night it back fired at 70mph it was so loud the cars next to me slammed on brakes. Of course I loss power temporarly but I think I got it under control today.
Old Jan 24, 2007 | 03:34 PM
Erich_121's Avatar
Erich_121
i wouldnt rule out a loose timing chain either, especially if you have bad low end power, and a rough idle
Old Jan 26, 2007 | 01:55 PM
zosdakota's Avatar
zosdakota
It still backfires every now and then. Could a bad O2 sensor cause that as well?
