difference 5.2 & 4.7
Old Jan 22, 2007 | 09:54 PM
kayakman's Avatar
kayakman
Default difference 5.2 & 4.7
I owned a'91 Dakwith a 318 or 5.2 litre V8 extended cab with a 3:91 axle. Can you guystell me, is there any difference which feels more powerful or have more grunt. The 5.2 or the 4.7.
Old Jan 22, 2007 | 10:20 PM
jnellydodge's Avatar
jnellydodge
Default RE: difference 5.2 & 4.7
My 4x4 98 dak with the 5.2feltevery bitas "peppy" as my uncles 4x4 02 dak with the 4.7....id say they're pretty close to the same as far as which feels like it has more power:
4.7= 230-235 hp/295 torque
5.2=230 hp/300 torque
Old Jan 22, 2007 | 11:56 PM
imnothot02's Avatar
imnothot02
gas milage my jeep had the 5.2 it was a great motor the dak has the 4.7 way more peppy either is a good plan dont get the 5.9 or the 3.9 v-6 tho gas hogs and no gain..
Old Jan 30, 2007 | 02:03 PM
deerang's Avatar
deerang
your rear axle will also make a diffrerence to the seat of the pants feel. The 4.7L I believe only comes with a 3.55
Old Jan 31, 2007 | 04:11 AM
horatio102's Avatar
horatio102
ORIGINAL: imnothot02
No gain from the 5.9?? It's got 15% more torque and a bit more horsepower too. It's got more potential as well. I had the 4.7 in my Jeep and it was a great motor, felt more like a high revving car motor than a grunty truck motor though. I'd take the 5.9 for real truck work any day.
Old Jan 31, 2007 | 04:18 AM
dodgerules86's Avatar
dodgerules86
The 1991 and below 5.2L (and 3.9L, for that matter), produced much less power than 1992 and above.
1991 5.2L: 170HP.
Old Jan 31, 2007 | 04:20 AM
turbot_bird's Avatar
turbot_bird
I liked my 5.9 ram, .............I miss it
Old Jan 31, 2007 | 12:51 PM
Erich_121's Avatar
Erich_121
The 4.7 were first made for the 1999 Jeep Cherokee producing 230HP and 295ft-lbf. The 5.2 is an evolution of the 318. It received the Magnum V8 name with new manifolds and heads in 1992. Major changes that year include the addition of multiport fuel injection, a new higher-flow valve angle, increased valve lift, and larger exhaust. Power was up to 230hp and 325tq, with 300 ft·lbf of torque, from 170hp previously. The 5.9 or called the 360, has the same block as the 318, but with different heads. It has 230hp with 325ft·lbf of torque. With the addition of a hemi in 2003 the 360 has 250HP with 345ft·lbf. And of course my engine, the 3.9 is just a 318 with 2 cylinders removed. How nice.
Old Jan 31, 2007 | 02:45 PM
horatio102's Avatar
horatio102
Check your numbers, some are a bit off.
318 = 5.2, the Magnum designation came with higher compression, better heads, better intake manifold, and a host of other changes. The 318 and 360 do not share a block, as the 360 has larger crank bearings. They're definitely related, but the casting is different. The 5.2's output was 230hp and 300lb-ft, or thereabouts. The 5.9's output was 245-250hp and 335-345lb-ft. The RT models got a minor ECU tweak and different exhaust for the extra power. All magnum 318 and 360s share a camshaft in factory applications.
Old Jan 31, 2007 | 03:27 PM
Chris's Avatar
Chris
ORIGINAL: horatio102
Exactly. I am glad you got to that one before I did because I would have been slightly more defensive over the beloved 5.9. Not only is it more powerful in both HP and Torque numbers, the aftermarket community embraced it with parts that range from air filters to turbo chargers. Easily one of the nicest motors IMHO.
