tires
Old Jan 24, 2007 | 01:00 AM
hdryder's Avatar
hdryder
Default tires
Ok maybe someone here can help me.I have an 02 dakota quad cab with a 3" body lift.What is the largest size tires I can run as an every day driver with the least amount of problems.(gas mileage,clearance etc.)
Old Jan 24, 2007 | 01:09 AM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: tires
Welcome, I am going to move your question over to the Dakota section, you will get a quicker response.
Old Jan 24, 2007 | 01:13 AM
DakotaMan's Avatar
DakotaMan
Default RE: tires
31x10.5 if you are worried about gas but you can get 32x11.5 depending on your offset of your rims but even then i would say you should be fine.
Old Jan 24, 2007 | 02:19 PM
Chris's Avatar
Chris
Default RE: tires
With a 3" body lift you will be able to run 33x12.5x15 with the correct offset and minor trimming.
Old Jan 24, 2007 | 03:32 PM
Erich_121's Avatar
Erich_121
Default RE: tires
32's
Old Jan 24, 2007 | 11:01 PM
imnothot02's Avatar
imnothot02
Default RE: tires
what about on a stock 16 inch rim slt truck? stock is 265 70 what about 195 70 ?
imnothot02's Avatar
imnothot02
Default RE: tires
