dash warning lights
Old Jan 27, 2007 | 01:07 AM
boohoops's Avatar
boohoops
Default dash warning lights
every now and then, my a.b.s. and brake warning lights stay lit up after my truck is started. they stay on while driving but dont affect my driving. the e-brake is disengaged but the lite is on and my brakes work fine with th light is on. this usually occurs when it is very cold out.is this normal or do i hav a serious issue on my hands?
Old Jan 27, 2007 | 04:03 AM
dodgedakota98luver's Avatar
dodgedakota98luver
Default RE: dash warning lights
well if you read in your manual it says that if thoes lights come on it will not affect the overall driveability of the vehicle. it just means that the antilock function of your breaks will not work for instance if you do some hard breaking the tires will lock up solid and slide easier
Old Jan 27, 2007 | 04:48 AM
jakebank's Avatar
jakebank
I'm pretty sure it can also mean that you are low on brake fluid.
Old Jan 27, 2007 | 05:00 AM
dodgedakota98luver
ah yes very true.its so easy to overlook the simple things. i would definetlycheck your brake fluid level before you do anything. If not then it could be a fuse or a relay check the box with all the fuses and relays under the hood it should be on the drivers side
Old Feb 7, 2007 | 12:13 AM
boohoops's Avatar
boohoops
well i added th needed brake fluid but it still comes on occasionally. i still hav to check the relays an stuuf. tthanks
Old Feb 9, 2007 | 10:01 PM
boohoops's Avatar
boohoops
finally solved the problem. the brakes needed fluid and a fuse replaced. thanks for ur help
