Lost MAJOR MPG, '02 4.7 L
Old Jan 31, 2007 | 10:44 PM
punkwood2k's Avatar
punkwood2k
Default RE: Lost MAJOR MPG, '02 4.7 L
ORIGINAL: Moody Blues
I was just wondering what grade of fuel your using?If it is a stage 2 they were made just for the high Octane gas.The stage 1s could run the 87 octaneStage 2s can not run no less then 89 it says it prefers 91 but can get away with 89.This could be why the drastic drop.The 70mm body will suck a couple not that much thoe.Also dont know if there is that much dif in the 02s from 03s but my Fuel rating is 15 in city 17 on Highways.I have a 2003 Quad cab slt 4.7 litter with few mods.
I am running 87 octane. I wasnt aware of the need for 91. I'll try that on my next tank of gas.
Old Jan 31, 2007 | 10:57 PM
horatio102's Avatar
horatio102
O2 sensors can fail to operate properly without throwing codes. I believe they're supposed to, but that's not always the case.
It could be driving style, that has a huge impact on economy. When I don't lead-foot it around I can get about 15-16mpg on the highway, but when I drive "normally" my mileage goes down to 12.5, and the exhaust, K&N FIPK, Hypertech 93 octane tune haven't affected it at all.
Old Feb 1, 2007 | 02:39 AM
jonnymagnum's Avatar
jonnymagnum
when my O2 sensor went, it didnt through a code at all. well until it got soo bad it would not idle at all. I was getting 20-21mpg and when my O2 sensor crapped out I was getting 15mpg.
you can yank your O2 sensor out and clean it. but thats just a temp. solution.
Old Mar 29, 2007 | 02:24 AM
DakotaRT03's Avatar
DakotaRT03
o2 sensors play a very important roll in addition to many other sensors on our new technology engines. In my opinion, when trying to utilize fuel economy, drop the upgrades. Im sure the combination of the performance adders are causing your poor fuel economy, check your o2 sensor and cat as virused recommended.
Old Mar 29, 2007 | 04:27 AM
horatio102's Avatar
horatio102
I can't speak for the Jet stage 2 or whatever CAI and 70mm intake he's got, but I gained mileage at cruise when I went with the FIPK and Hypertech 93 octane tune.
Standing on the gas though my mileage went down.
Old Mar 29, 2007 | 09:08 AM
BAnders's Avatar
BAnders
yes, check the O2 sensor. if it is bad it will make the computer think the engine is running lean and dump more fuel.
Old Mar 29, 2007 | 10:54 AM
HankL's Avatar
HankL
11 to 13 is a typical mixed driving MPG number for a 4.7 Ram 4x4
based on added up and averaging what owners at this and other forums report.
For a second opinion go to the bottom of this review and read:
http://www.usatoday.com/money/perfi/...0-ram.htm#more
sample quote:
• How thirsty? Ratings for city/highway driving: V-6, manual: 15/21 miles per gallon; V-6, automatic: 15/20 mpg. 4.7 V-8, 4x2, manual or automatic: 14/19 mpg. 4x4 manual: 13/18 mpg; automatic: 13/17. 5.9 V-8, 4x2, automatic: 12/18; 4x4: 11/16.
Reality: 4.7 V-8, Quad Cab, 4x2, automatic got 13.1 mpg, according to the truck's computer, in 700 miles of driving: 475 on interstate, 225 on suburban roads. 4x4 version: 11.8 mpg in mainly suburban driving. All engines use regular-grade gas.
end quote
If you really want to check to see if your truck's 4.7 engine is 'healthy'
do a gas station to gas station 'test run' of at least 100 miles
at a steady 60 mph on an interstate highway
on a day that there is no more than 7 mph of wind
and the temperature is between 50 and 75.
The hand calculated MPG should be at least 19 for a 4x4
and 21 MPG for a 4x2.
Knock off 2 MPG if big mudder style tires are on the truck.
Old Mar 29, 2007 | 09:59 PM
2002Dakota4.7L's Avatar
2002Dakota4.7L
Try this one. I also have an 02 Quad cab dak with the 4.7L. No mods that I know of(bought used). I get about 15 mpg but the fuel gauge light comes on at 200 miles almost like clockwork. I fill it up and can never cram more than 16-18 gallons. But this truck is supposed to have a 24 gallon tank. My guess and the guess of a mechanic I spoke to briefly was that the fuel level sender unit is bad. He also said that Dodge trucks were horrible with fuel level senders in the late 90's and early 2000's. Anyone else have a situation like this? Not to rob the post but thought I would mention it.
Old Mar 30, 2007 | 04:02 AM
DakotaRT03's Avatar
DakotaRT03
Yeah, thats a good question. You should definitly make a post about it.
Old Mar 30, 2007 | 10:55 AM
imnothot02's Avatar
imnothot02
proaly not a 24 gal tank..
