help on shimmy diagnostic
Old Feb 4, 2007 | 12:02 AM
amuzed's Avatar
amuzed
Default help on shimmy diagnostic
I have a 2000 dodge dakota 2-wheel drive, 4 -cyl., standard cab (97,000 miles). It has a shimmy at 15-30 miles per how (steering wheel jerks back and forth ~ 1/2 inch) and drifts to the right. I took it to the dealer for a diagnosis, and they said I need a new clutch. I asked how does a bad clutch causes a shimmy in a rear wheel drive. The response was throw-out bearing causing vibration. I have not replaced the clutch. On the way home at 20 mph, I push in the clutch, and the shimmy stayed the same. Is the dealer's diagnosis reasonable of should I get a second opinion?
Old Feb 4, 2007 | 12:51 AM
2000Dakotadriver's Avatar
2000Dakotadriver
Default RE: help on shimmy diagnostic
I'd get a second opinion. What has caused my steering wheel shimmy before is out of balance tires. But I am sure there are a whole host of other reasons why. As for drifting to the right, i'd check wheel alignment. How you are supposed to do that someone else will have to answer that.
Old Feb 11, 2007 | 01:59 PM
amuzed's Avatar
amuzed
Default RE: help on shimmy diagnostic - thanks
Thanks, I needed new tires and when I had tires replaced the shimmy went away. Now all I need to do is get the diagnostic fee back from the dealer - really likely.
Old Feb 11, 2007 | 02:08 PM
superdak05's Avatar
superdak05
if you have not had your tires rotated and balanced in awhile. the steel belts in them might have slipped causing premature wear.you cant see this on the treads it is internal. the belts break away from each other. try putting the rear tires on the frt and vise cersa to see if this cures the problem.
