Superchip Programer
Old Feb 6, 2007 | 10:04 PM
DakinUK's Avatar
DakinUK
Default Superchip Programer
Hi,
I've got a Superchips Programer which I like a lot. As well as the performance gains, I've used it enough reading and clearing fault codes to have paid for itself in workshop charges.
The one question I have is that after using it to read/clear a code it goes back to the stage where it asks wheather you want to, A:Program or Biagnose. Is it safe to switch off the ignition and disconect at this point? The only other way is to choose A and go through the process of unloading the current program, then re-installing it. This way you get to the end and it says to disconect the tuner.
I got so fed up doing the long way when clearing codes (got the recuring P0442! Will get new cap when next in States!) that I've just switched off and dissconected after clearing the code a couple of times and it doesn't seem to have done any harm but I just wanted to know if I was going to do any damage.
On a related story, I found that on the highest performance setting, I was getting a bit of "pinging" under full throttle. I'd been told that a 180 Stat would help. I bought one on my last visit but haven't gotten round to fitting it. The past couple of weeks have seen the weather going into the 40's and sometimes into the low 30's and I can't get it to "ping" so I think the cooler Stat will have to go in when it warms up. I will let you know.
Thanks,
Paul
Old Feb 7, 2007 | 03:17 AM
horatio102's Avatar
horatio102
Default RE: Superchip Programer
You're using 91+ octane when running the highest setting, right? I get pinging too, but I think my intake plenum gasket is leaking again. I did notice a decrease in pinging after swapping out the thermostat though.
Old Feb 7, 2007 | 10:48 AM
DakinUK's Avatar
DakinUK
I've been using what we call Super Unleaded over here, depending on who you buy it from, it varies from 97 to 99 Octane but I know that we measure the octane rating slightly differently. It would equate to between 91 and 93 on your scale. I don't think the 4.7 is efected by the plenum chamber leaks of the LA engines but correct me if I'm wrong. I still don't understand why a low stressed truck engine has these problems when a highly stressed motorcycle engine happily runs on regular unleaded. It runs far higher compression and ignition advance.
Thanks again,
Paul
Old Feb 7, 2007 | 12:35 PM
Moody Blues's Avatar
Moody Blues
I go by what it says If I run the performace or Torque setting it has no less then 91 Octane in her.I have never expierienced Pinging.My friend ran the performance setting with 89 Octane and he thought his truck was gonna throw a rod it was pinging so bad.Dont be Bullheaded and run whatever is recomended.
Old Feb 7, 2007 | 12:39 PM
Moody Blues
Sorry to avoid your main Question.I would not know but just to be safe if were me I would grind my teeth and take the extra time just to be safe my trucks worth that to me.
Old Feb 9, 2007 | 12:33 AM
asmodeus289's Avatar
asmodeus289
I have the same problem with pinging. I'm running the 91 Performance Tune and have the 180 degree thermostat in my 4.7. Mine only seems to ping under full throttle when I run certain brands of gas.
