headlight condensation
Old Feb 8, 2007 | 07:48 PM
revjchacker's Avatar
revjchacker
Default headlight condensation
Go figure. It's -15 degrees. I just bought a '03 Dakota (traded my Charger, sucks in snow, bad in cold weather, getting married in June, need to save $$$). I noticed today that one headlight is fogged up. Wasn't like that when I drove it from the dealer yesterday. My question is, I know there was a TSB for the same issue in the Charger. Does anyone know if there was a TSB for this problem in other models?
RevHacker
Minnesota
Old Feb 8, 2007 | 08:21 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: headlight condensation
min did that after I put new bulbs in. I guess I didnt have one seated in just right. cause after I took it out and put it back in. it never fogged up again.
Old Feb 8, 2007 | 10:52 PM
Chris's Avatar
Chris
The seal in the light has been compromised. You can do one of two things. First, buy a new headlight. (I would get a pair because one will most likely have been faded more than the other) Or second, remove the headlight after you take the bulb out. Set in the oven at about 250 degrees. Check it every minute or so to see if the front "face" on the headlight will come off. It takes a minute for the glue to become pliable enough for it to be removed. Once seperated, wait for it to cool back off then apply ample amounts of epoxy for a seal and reapply.
It might be something as simple as a hole in the back of the headlight assembly that is letting moisture in, either way, the culprit is a lack of a seal between the front and rear assemblies of the headlight.
Old Feb 9, 2007 | 12:52 AM
imnothot02's Avatar
imnothot02
on a second tsb note i think you have a recall for your upper ball joints..
Old Feb 9, 2007 | 02:47 AM
revjchacker
I made sure the ball joints had already been done. There was only one previous owner and he had all the recalls taken care of.
Thanks for your help!
Old Feb 10, 2007 | 12:21 AM
User's Avatar
User
ORIGINAL: virused
nice.. ill try the oven thing, never thought about that, both my headlights are like his, or just sun damaged.. i just bought new silverstars for them when i got the truck.. and i noticed one of the headlights started to go back to normal (dry out)..
